跳转到主内容
Samsung Galaxy Tab E 8.0 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Camera: 步骤 2 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Camera: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Front Camera: 步骤 3 中的图像 1,3 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Front Camera: 步骤 3 中的图像 2,3 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Front Camera: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S13-G4, White Fall 2018 Cal Poly, Team S13-G4, White Fall 2018 的会员
CPSU-WHITE-F18S13G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 2,206
