跳转到主内容
Samsung Galaxy Tab A 9.7 Rear Camera Replacement
你所需要的
  1. Samsung Galaxy Tab A 9.7 Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 2 中的图像 1,1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 3 中的图像 1,1
    • Remove one of the iFixit opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  5. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Disconnect all wires and strips that connect the motherboard to any other part of the device with an iFixit opening tool.
    • Lift up gently on all wires and strips.
  6. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard out of the back panel using an iFixit opening tool.
    • Be gentle when wiggling the motherboard out from underneath the battery's protective edge.
  7. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: 步骤 7 中的图像 1,1
    • Pull off the rear camera on the back of the motherboard and replace.
结论
Makenzie D'Elia
于04/09/19注册
313 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Hovde Spring 2019 IUPUI, Team S1-G3, Hovde Spring 2019 的会员
IUPUI-HOVDE-S19S1G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 262
