简介
If your display is unresponsive or cracked, this is the guide for you! As you follow the steps below, please be careful to not damage the other components.
  1. Insert a metal spudger between the back case and the screen of the device.
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
      • There will be an audible click every time a snap releases.
    添加评论
  2. Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
    添加评论
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
    添加评论
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
    添加评论
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
    添加评论
    • Remove the green tape that is covering the ZIF connections.
    添加评论
    • Use a plastic opening tool to lift the black tab on both ZIF connectors.
    添加评论
    • Use a spudger to release the display flex able from the ZIF connector.
    • Pull out the front facing camera.
    添加评论
    • Undo the press connectors with a plastic opening tool.
    添加评论
    • Remove the two 2.8mm screws holding in the magnetic brackets with a PH00 bit.
    添加评论
    • Pull out the two magnetic brackets.
    添加评论
    • Remove the four 2.8mm screws holding in the daughterboard with a PH00 bit.
    添加评论
    • Use a spudger to help lift up the daughterboard.
      • There is some glue so pry carefully.
    • Remove the daughterboard.
    添加评论
    • Remove the four 2.8mm screws holding in the motherboard with a PH00 bit.
    添加评论
    • Pull out the motherboard.
    添加评论
结论
2等其他人完成本指南。
Blake Klein
于2017年01月29日注册
36,799 信誉积分
创作了35篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了6,999篇指南
Hi Blake, this stops before getting to the screen?
Tom Kell - 回复
lollllllll.. this is incomplete
mrdamnslow - 回复
添加评论
浏览统计数据:
过去的24小时: 15
过去的7天: 52
过去的30天: 240
总计 2,383
