跳转到主内容
Samsung Galaxy Tab A 9.7 Button Replacement
你所需要的
  1. Samsung Galaxy Tab A 9.7 Button Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Button Replacement, Speakers: 步骤 2 中的图像 1,2 Samsung Galaxy Tab A 9.7 Button Replacement, Speakers: 步骤 2 中的图像 2,2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Button Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
  4. Samsung Galaxy Tab A 9.7 Button Replacement, Charging Port: 步骤 4 中的图像 1,3 Samsung Galaxy Tab A 9.7 Button Replacement, Charging Port: 步骤 4 中的图像 2,3 Samsung Galaxy Tab A 9.7 Button Replacement, Charging Port: 步骤 4 中的图像 3,3
    • Remove the four 2.8mm #000 Phillips screws that hold the charging port and headphone jack in place.
  5. Samsung Galaxy Tab A 9.7 Button Replacement: 步骤 5 中的图像 1,1
    • Disconnect the green square connector from the motherboard. To do so, put the flat end of the plastic opening tool underneath the connector and push down.
    • During reassembly, two clicks signify the charging board is completely attached to the motherboard.
  6. Samsung Galaxy Tab A 9.7 Button Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Place the heavy duty spudger underneath the charging port and push down to remove the charging port.
    • To reinsert the charging port, angle the port downwards towards the battery. Then press down the outside edge of the charging port.
  7. Samsung Galaxy Tab A 9.7 Button Replacement: 步骤 7 中的图像 1,1
    • Peel the charging assembly from the device to completely remove the charging port from the device.
  8. Samsung Galaxy Tab A 9.7 Button Replacement, Button: 步骤 8 中的图像 1,1
    • Using a plastic spudger, work around the edge of the screen, prying the screen away from the devise.
    • Once the the cover is removed, set it aside.
  9. Samsung Galaxy Tab A 9.7 Button Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab A 9.7 Button Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers or a plastic spudger, press on the back of the button until it pops out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 994
