跳转到主内容
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 3 中的图像 3,3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Remove the auxiliary port from the case.
结论
5等其他人完成本指南。
Bradley Watson
于02/15/17注册
1,079 声望
创作了4篇指南
团队
USF Tampa, Team 5-4, Passmore Spring 2017 USF Tampa, Team 5-4, Passmore Spring 2017 的会员
USFT-PASSMORE-S17S5G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 58
总计 3,997
