跳转到主内容
Samsung Galaxy Tab A 7.0 Battery Replacement
你所需要的
  1. Samsung Galaxy Tab A 7.0 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, gently lift the black tab locking the wire connecting the battery to the motherboard.
    • Pull wire from connector.
    • This is the only connection for the battery to the motherboard.
  4. Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab A 7.0 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery from the device.
    • Separating tool may be needed in order to lift battery from device.
结论
14等其他人完成本指南。
Bradley Watson
于02/15/17注册
1,079 声望
创作了4篇指南
团队
USF Tampa, Team 5-4, Passmore Spring 2017 USF Tampa, Team 5-4, Passmore Spring 2017 的会员
USFT-PASSMORE-S17S5G4
3 名成员
创作了8篇指南
4条评论
I found there was a layer of double-sided tape backing the battery, and I had to use a flathead screwdriver to get enough force to lever it up. This does not significantly change the guide.
brunius - 回复
It would be nice if you showed which side to remove.
Bob White - 回复
The OEM battery in my device expanded and pushed the screen from the housing. I had to temporarily separate the screen from the housing while leaving the connectors in their sockets while I pried the front housing from the back to reveal the battery. Once the front and back of the chassis were separated, I reattached the screen to the front housing and continued with the procedure. A heat gun made the process much easier by loosening the tape between the screen and housing, but was not necessary to lift the battery or separate the front from the back of the chassis.
Dan Murphy - 回复
Bought a new battery, replaced as said, but seems like new battery is dead. How does one boost it? If I plug into charge, it almost seems like te sceen "flashes" but doesnt come on or show charge bar. Please help.
anciska.mills - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 78
过去 30 天: 437
总计 19,066
