跳转到主内容
Samsung Galaxy Tab A 10.1 Speaker Replacement
你所需要的
  1. Samsung Galaxy Tab A 10.1 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab A 10.1 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 2 中的图像 2,2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Speaker Replacement, Disconnecting the battery: 步骤 3 中的图像 1,1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 5 中的图像 3,3
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Speaker Replacement, Battery removal: 步骤 6 中的图像 1,2 Samsung Galaxy Tab A 10.1 Speaker Replacement, Battery removal: 步骤 6 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Use Phillips # 000 to remove the 4 mm .3 cm screw on each speaker.
    • If you encounter a stripped screw, see iFixit’s guide on how to remove it here.
  8. Samsung Galaxy Tab A 10.1 Speaker Replacement: 步骤 8 中的图像 1,1
    • Place the plastic opening tool on the edge of the speaker.
    • Lodge the plastic opening tool under each speaker and lift them up and out of the device.
结论
2等其他人完成本指南。
Isabella Li
于10/02/17注册
2,379 声望
创作了7篇指南
团队
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G6
4 名成员
创作了26篇指南
2条评论
Where is a good place to buy the replacement speaker?
Max Alberts - 回复
Where is a good place to buy a speaker?
Max Alberts - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 4,231
