Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
Remember to remove the micro SD card (if present) before you begin.
Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
Lift the back panel off of the device.
The back panel will make a clicking noise while being lifted off of the device.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
Slide the orange ribbon cables out of the ZIF connectors.
Remove the front-facing camera.
Lodge the plastic opening tool under and lift the motherboard out of the tablet.
Be careful not to snag any connectors.
Remove the metal bracket that was underneath the charging port and set aside.
嵌入本指南
选择尺寸并复制下面的代码嵌入本指南,为你网站/论坛的一个小插件。
预览
