跳转到主内容
Samsung Galaxy Tab A 10.1 Back Panel Replacement
你所需要的
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab A 10.1 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
结论
9等其他人完成本指南。
Isabella Li
于10/02/17注册
2,376 声望
创作了7篇指南
团队
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G6
4 名成员
创作了26篇指南
一条评论
Why need to remove cables when only the back has to be replaced ?
nabe_03 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 19
过去 30 天: 88
总计 11,780
