跳转到主内容
Samsung Galaxy Tab A (2019) Screen Replacement
你所需要的
视频介绍
结论
17等其他人完成本指南。
Nick Myers
于04/15/18注册
3,730 声望
创作了26篇指南
9条评论
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - 回复
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - 回复
Use a heat gun it will help that’s what I would do
nicholaswiding -
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 57
过去 30 天: 288
总计 14,537
