跳转到主内容
Samsung Galaxy Tab 8.9 Vibration Motor Replacement
你所需要的
  1. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Insert Opening tool: 步骤 1 中的图像 1,1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Insert second tool: 步骤 2 中的图像 1,1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 3 中的图像 1,1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 4 中的图像 1,1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Battery: 步骤 5 中的图像 1,1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  6. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 6 中的图像 1,1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  7. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 7 中的图像 1,1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  8. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 8 中的图像 1,1
    • Use your hands to open the back cover.
  9. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove Green Tape: 步骤 9 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove Green Tape: 步骤 9 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove Green Tape: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  10. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 10 中的图像 2,2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  11. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 11 中的图像 3,3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  12. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Disconnect Battery from MotherBoard: 步骤 12 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Disconnect Battery from MotherBoard: 步骤 12 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Disconnect Battery from MotherBoard: 步骤 12 中的图像 3,3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  13. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 13 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  14. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove the Battery: 步骤 14 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove the Battery: 步骤 14 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove the Battery: 步骤 14 中的图像 3,3
    • Use a spudger to lift up and separate the battery from its housing.
  15. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Motherboard: 步骤 15 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Motherboard: 步骤 15 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Motherboard: 步骤 15 中的图像 3,3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  16. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 16 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 16 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 16 中的图像 3,3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  17. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 17 中的图像 1,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 17 中的图像 2,3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 17 中的图像 3,3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  18. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 18 中的图像 1,2 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 18 中的图像 2,2
    • Pull away the motherboard from the housing.
  19. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Vibration Motor: 步骤 19 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grab wire lead and gently lift to release glue holding wire lead to housing.
  20. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 步骤 20 中的图像 1,1
    • Use opening tool to pry motor from housing.
结论
Eric Bird
于05/09/17注册
543 声望
创作了5篇指南
团队
IUPUI, Team S4-G2, Harley Spring 2017 IUPUI, Team S4-G2, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S4G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 207
