跳转到主内容
Samsung Galaxy Tab 8.9 Speaker(s) Replacement
你所需要的
  1. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Insert Opening tool: 步骤 1 中的图像 1,1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Insert second tool: 步骤 2 中的图像 1,1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 3 中的图像 1,1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 4 中的图像 1,1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Charging Port: 步骤 5 中的图像 1,1
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 6 中的图像 2,2
    • Insert a spudger under the orange tab.
    • Pry open the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 7 中的图像 1,1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #00 screwdriver, unscrew the 4 screws (3mm) that are holding the charger port and speaker support.
  9. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 9 中的图像 1,1
    • Insert opening tool to pry support from the housing.
  10. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 10 中的图像 2,2
    • Desolder the two connections to separate the speakers from the charger port.
  11. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: 步骤 11 中的图像 1,1
    • Separate charging port from speaker assembly.
结论
Eric Bird
于05/09/17注册
543 声望
创作了5篇指南
团队
IUPUI, Team S4-G2, Harley Spring 2017 IUPUI, Team S4-G2, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S4G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 134
