跳转到主内容
Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Insert Opening tool: 步骤 1 中的图像 1,1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Insert second tool: 步骤 2 中的图像 1,1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Motherboard: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Motherboard: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  6. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  7. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 7 中的图像 3,3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  8. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Pull away the motherboard from the housing.
  9. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Flip Motherboard: 步骤 9 中的图像 1,1
    • After removing motherboard from device, flip motherboard over.
  10. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Locate Camera: 步骤 10 中的图像 1,1
    • Camera is located in the center of motherboard.
  11. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Disconnect Flex Ribbon: 步骤 11 中的图像 1,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Disconnect Flex Ribbon: 步骤 11 中的图像 2,3 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Disconnect Flex Ribbon: 步骤 11 中的图像 3,3
    • Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard.
  12. Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Remove Camera: 步骤 12 中的图像 1,2 Samsung Galaxy Tab 8.9 Rear Facing Camera Replacement, Remove Camera: 步骤 12 中的图像 2,2
    • Remove the camera from the motherboard.
结论
Aleezee True
于09/30/14注册
532 声望
创作了3篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 303
