跳转到主内容
Samsung Galaxy Tab 8.9 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 2 中的图像 1,1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: 步骤 8 中的图像 3,3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: 步骤 10 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: 步骤 10 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: 步骤 10 中的图像 3,3
    • Use a spudger to lift up and separate the battery from its housing.
  11. Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  12. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  13. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  14. Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Tab 8.9 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Pull away the motherboard from the housing.
结论
4等其他人完成本指南。
Aleezee True
于09/30/14注册
532 声望
创作了3篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 2,341
