跳转到主内容
Samsung Galaxy Tab 7.7 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Tab 7.7 Motherboard Replacement, Opening the tablet: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Opening the tablet: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Opening the tablet: 步骤 1 中的图像 3,3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Motherboard Replacement, Disconnecting the circuit board: 步骤 2 中的图像 1,1
    • Detach the ribbon cable.
  3. Samsung Galaxy Tab 7.7 Motherboard Replacement, Disconnecting  the thin connector cable: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 7.7 Motherboard Replacement, Disconnecting  the thin connector cable: 步骤 3 中的图像 2,2
    • Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit!
  4. Samsung Galaxy Tab 7.7 Motherboard Replacement, Unscrewing the motherboard: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Unscrewing the motherboard: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Unscrewing the motherboard: 步骤 4 中的图像 3,3
    • Remove the 4 screws securing the motherboard.
  5. Samsung Galaxy Tab 7.7 Motherboard Replacement, Replacing the motherboard: 步骤 5 中的图像 1,2 Samsung Galaxy Tab 7.7 Motherboard Replacement, Replacing the motherboard: 步骤 5 中的图像 2,2
    • Replace the original motherboard with the new circuit board.
结论
2等其他人完成本指南。
Stephanie Wong
于09/26/14注册
973 声望
创作了5篇指南
团队
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G2
4 名成员
创作了9篇指南
一条评论
Thanks for this post.
But, that was the speaker module and docking port assembly, not the motherboard!
The title is misleading!
valuesphilippines - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 3,188
