跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to replace the audio jack when it either ceases to function, or is functioning incorrectly.
  1. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
    • Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
  2. Detach the connector that connects the audio jack to the flex cable.
    • Detach the connector that connects the audio jack to the flex cable.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
    • Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
  5. Pick up and remove the defective audio jack. Pick up and remove the defective audio jack.
    • Pick up and remove the defective audio jack.
结论
2等其他人完成本指南。
Stephanie Wong
于2014年09月26日注册
946 信誉积分
创作了5篇指南
团队
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G2
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 572
