跳转到主内容
简介
This guide will give you step-by-step instructions to replacing the flex cable of a Samsung Galaxy Tab 7.7. This can help resolve issues such as the camera or audio jack not communicating with the motherboard.
  1. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Unsnap all the ribbon cables from the flex cable. Unsnap all the ribbon cables from the flex cable.
    • Unsnap all the ribbon cables from the flex cable.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Remove the screws securing the flex cable to the chassis.
    • Remove the screws securing the flex cable to the chassis.
  5. Remove the original flex cable and replace it with the flex cable. Remove the original flex cable and replace it with the flex cable.
    • Remove the original flex cable and replace it with the flex cable.
结论
Stephanie Wong
于2014年09月26日注册
919 信誉积分
创作了5篇指南
团队
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G2
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 607
