跳转到主内容
Samsung Galaxy Tab 7.7 Battery Replacement
你所需要的
  1. Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: 步骤 1 中的图像 3,3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Battery Replacement, Disconnecting the battery: 步骤 2 中的图像 1,1
    • Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
  3. Samsung Galaxy Tab 7.7 Battery Replacement, Unscrewing the battery: 步骤 3 中的图像 1,1
    • Remove the 6 screws securing battery.
  4. Samsung Galaxy Tab 7.7 Battery Replacement, Replacing the battery: 步骤 4 中的图像 1,1
    • Remove the original battery, replace it with a new one.
结论
8等其他人完成本指南。
Stephanie Wong
于09/26/14注册
973 声望
创作了5篇指南
团队
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 7,767
