简介
This guide will show you how to remove and replace the rear facing camera on the Samsung Galaxy Tab 4 8.0 Wi-Fi.
你所需要的
Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
The rear facing camera will be located just to the right and below the front facing camera, near the top and center of the motherboard.
另外一个人完成了本指南。
