跳转到主内容
Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Before you being the replacement process, make sure the tablet is completely powered off.
    • Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
    • Right-handed users will probably be more comfortable prying in a clockwise movement, while left-handed users will feel more comfortable doing a counter clockwise movement.
    • When taking off the rear case there will be periodic clicking noises. Do not worry about those noises. They are just the rear case being disconnected.
    • Be careful not to use too much force as the plastic clips can easily be broken.
  2. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Place the tablet screen down on a clean surface.
    • Grasp the back panel and lift it from the device.
  3. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement, Front Facing Camera: 步骤 3 中的图像 1,1
    • The front facing camera's ribbon cable is located at the top edge of the motherboard, slightly left of center.
    • Slide the flat end of the blue plastic opening tool underneath the connector at the end of the ribbon cable.
  4. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  5. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
结论
Cameron Morrow
于04/14/16注册
384 声望
创作了3篇指南
团队
Cal Poly, Team 25-3, Maness Spring 2016 Cal Poly, Team 25-3, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 319
