跳转到主内容
Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement
你所需要的
  1. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 2 中的图像 2,2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 3 中的图像 2,2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Battery: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Battery: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Battery: 步骤 4 中的图像 3,3
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  5. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 5 中的图像 1,1
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  6. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 6 中的图像 2,2
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  7. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 7 中的图像 3,3
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
  8. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Motherboard: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Motherboard: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  9. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 9 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  10. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 10 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  11. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 11 中的图像 3,3
    • Using the spudger gently wedge the blue wire out of its compartment.
  12. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 12 中的图像 1,1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  13. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  14. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 14 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 14 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 14 中的图像 3,3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  15. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 15 中的图像 2,2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  16. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 16 中的图像 1,1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  17. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 17 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 17 中的图像 2,2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  18. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement, Vibration Motor: 步骤 18 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    购买
    • Use the angled tweezers to lift up the orange rectangular electrical connector, this will disconnect the vibration motor from the motherboard.
  19. Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 19 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Vibration Motor Replacement: 步骤 19 中的图像 2,2
    • Slide one arm of the angled tweezers beneath the orange electrical tape and the motor.
    • Gently pull upwards on the motor and electrical tape and remove the speaker from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 243
