跳转到主内容
Samsung Galaxy Tab 4 8.0 Verizon Speaker Replacement
你所需要的
  1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 2 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 3 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 4 中的图像 3,3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 5 中的图像 1,1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 7 中的图像 3,3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 8 中的图像 2,2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 9 中的图像 1,1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 10 中的图像 2,2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Speaker: 步骤 11 中的图像 1,1
    • Insert the opening tool tip into the crack between the speaker and device.
  12. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: 步骤 12 中的图像 1,1
    • Gently pry up on the speaker to disconnect the speaker from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 136
