跳转到主内容
Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement
你所需要的
  1. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 步骤 2 中的图像 2,2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 步骤 3 中的图像 2,2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Power/Lock and Volume Button: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Power/Lock and Volume Button: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Power/Lock and Volume Button: 步骤 4 中的图像 3,3
    • The button will be attached to the back casing of the tablet.
    • Using the spudger, first push the power/lock button then the volume button inwards from the opening towards the center of the tablet.
  5. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 步骤 5 中的图像 1,1
    • Using a precision tweezer, detach the clear plastic wire from the back casing by pulling the wire out of its slot.
  6. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 步骤 6 中的图像 1,1
    • Grab the power/volume button with a precision tweezer to completely lift the buttons out of the back casing.
结论
2等其他人完成本指南。
Ofelia Cruz
于09/14/15注册
1,119 声望
创作了5篇指南
团队
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,732
