跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement
你所需要的
  1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
    添加评论
  2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 2 中的图像 2,2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
    询问修复机器人
    添加评论
  3. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 3 中的图像 2,2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
    询问修复机器人
    添加评论
  4. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: 步骤 4 中的图像 3,3
    • The front camera's ribbon cable is located just above the battery, slightly to the left.
    • Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
    询问修复机器人
    添加评论
  5. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 5 中的图像 1,1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
    询问修复机器人
    添加评论
  6. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
    询问修复机器人
    添加评论
  7. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Facing Camera: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Facing Camera: 步骤 7 中的图像 2,2
    • The back camera will be located near the top of the tablet in the center above the battery.
    • Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
    询问修复机器人
    添加评论
  8. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 8 中的图像 1,1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the back camera’s metallic rectangular connector from its socket on the logic board.
    询问修复机器人
    添加评论
  9. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Squeeze the metallic rectangular piece with the tweezers to gently lift it from it's pit.
    询问修复机器人
    添加评论
  10. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: 步骤 10 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: 步骤 10 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: 步骤 10 中的图像 3,3
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
    询问修复机器人
    添加评论
  11. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 11 中的图像 1,1
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
    询问修复机器人
    添加评论
  12. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 12 中的图像 2,2
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
    询问修复机器人
    添加评论
  13. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 13 中的图像 3,3
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
    询问修复机器人
    添加评论
  14. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: 步骤 14 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: 步骤 14 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: 步骤 14 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
    询问修复机器人
    添加评论
  15. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 15 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 15 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 15 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
    询问修复机器人
    添加评论
  16. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 16 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 16 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 16 中的图像 3,3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
    询问修复机器人
    添加评论
  17. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 17 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 17 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 17 中的图像 3,3
    • Using the spudger gently wedge the blue wire out of its compartment.
    询问修复机器人
    添加评论
  18. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 18 中的图像 1,1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
    询问修复机器人
    添加评论
  19. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 19 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 19 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 19 中的图像 3,3
    在这个步骤中使用的工具:
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
    询问修复机器人
    添加评论
  20. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 20 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 20 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 20 中的图像 3,3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
    询问修复机器人
    添加评论
  21. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 21 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 21 中的图像 2,2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
    询问修复机器人
    添加评论
  22. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 22 中的图像 1,1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
    询问修复机器人
    添加评论
  23. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 23 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 步骤 23 中的图像 2,2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Ofelia Cruz
于09/14/15注册
1,119 声望
创作了5篇指南
团队
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 35
总计 3,202
