简介
After damaging your front camera, you might feel intimidated to dig into the Samsung Galaxy Tab 4 8.0. Replacing the front camera will only require, a plastic opening tool, tweezers, muscle strength, and these easy to follow instructions. The replacement will be a breeze, but be sure not use too much force when prying the device open.
你所需要的
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
The front camera's ribbon cable is located just above the battery, slightly to the left.
Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
