跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement
你所需要的
  1. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
    添加评论
  2. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 2 中的图像 2,2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
    询问修复机器人
    添加评论
  3. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 3 中的图像 2,2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
    询问修复机器人
    添加评论
  4. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
    询问修复机器人
    添加评论
  5. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 5 中的图像 1,1
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
    询问修复机器人
    添加评论
  6. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 6 中的图像 2,2
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
    询问修复机器人
    添加评论
  7. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 步骤 7 中的图像 3,3
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
17等其他人完成本指南。
Ofelia Cruz
于09/14/15注册
1,119 声望
创作了5篇指南
团队
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G3
4 名成员
创作了12篇指南
3指南评论
Everything in this guide looks pretty good. The only thing I would add to step one is to make sure you remove both the SIM card and the Micro SD card. Failure to do so can result in a broken SIM/SD card, slot or board they are connected to.
Cameron - 回复 分享
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
Jason Stephens - 回复 分享
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
Carlos Blanquer Bogacz - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 65
总计 26,909
