跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 7 中的图像 3,3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 8 中的图像 3,3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 9 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 9 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 9 中的图像 3,3
    • Flip the motherboard over to view the back side.
    • Locate the rear-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 10 中的图像 2,2
    • Use a plastic opening tool to unlock the rear-facing camera wire from the motherboard by flipping up the retaining flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 11 中的图像 2,2
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard
结论
团队
Cal Poly, Team 18-3, Forte Fall 2016 Cal Poly, Team 18-3, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G3
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 45
总计 932
