跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement
你所需要的
    1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: 步骤 1 中的图像 2,2
      • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
      • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 2 中的图像 3,3
      • Carefully remove the back panel from the frame of the device.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 3 中的图像 3,3
      • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
      • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
      询问修复机器人
      添加评论
    5. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 5 中的图像 3,3
      • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
      • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
      询问修复机器人
      添加评论
    6. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 6 中的图像 3,3
      • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
      询问修复机器人
      添加评论
    7. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 7 中的图像 3,3
      • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
      询问修复机器人
      添加评论
    8. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 8 中的图像 3,3
      • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
      • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 9 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 9 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 9 中的图像 3,3
      • Flip the motherboard over to view the back side.
      • Locate the rear-facing camera on the motherboard.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 10 中的图像 2,2
      • Use a plastic opening tool to unlock the rear-facing camera wire from the motherboard by flipping up the retaining flap.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 步骤 11 中的图像 2,2
      • Use your fingers to grip the camera and carefully pull it out and away from the motherboard
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 18-3, Forte Fall 2016 Cal Poly, Team 18-3, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G3
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 1,019
