跳转到主内容
Samsung Galaxy Tab 4 7.0 Speaker Replacement
你所需要的
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Speaker Replacement: 步骤 4 中的图像 2,2
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
结论
2等其他人完成本指南。
Aubrey Goodwin
于08/31/15注册
2,700 声望
创作了3篇指南
团队
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G3
4 名成员
创作了12篇指南
2条评论
Where can I order the new speaker?
Dorrie Stotko - 回复
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 3,917
