当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
Using the bent tweezers, carefully pull the flat cables away from the connectors.
Do not bend the flat cables at the tips as they may become permanently deformed.
You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
Work the spudger underneath the battery as shown and pry the battery away from the phone case.
The battery is attached to the case with adhesive, so a bit of force is required during removal.
Evenly heat the surface of the screen using your heating tool to loosen the adhesive that is holding the screen to the phone case.
If using the heating pad, you may have to reheat it once or twice during this process.
If you're using a heat gun, avoid heating one spot for more than a few seconds.
Carefully insert the spudger between the glass and the chrome outer frame of the tablet.
Now, slowly pry your way around the screen to loosen the glass from the frame.
After you’ve removed the glass from the screen, feed the chip connection through the phone casing.
The screen may need a little more force to separate from the upper edge of the tablet.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
