简介
If you don't have the heating pad available, either use a heat gun or a hair dryer with a high heat setting.
Starting from any corner of the tablet, carefully insert the plastic pry tool into the gap between the chrome frame and black back panel.
Slide the pry tool around the tablet to release the plastic locking clips. Pry the back plastic case down and slightly away from the device while the screen is facing up.
To begin the replacement of the motherboard, identify the wire strip connections that must be removed.
These connections can be removed using tweezers.
These chip connections can be released using the plastic opening tool.
Use tweezers to lift the small black flap and disconnect the wire from the motherboard.
Before you can remove the screen, you must first heat the surface evenly to loosen the adhesive.
Once you've loosened the screen from the tablet, be sure to feed the chip connection through its designated slot as indicated by the second photo.
Now the hardest part is done!
This was rather easy. I have been trying to find a place where install/repair guides are accurate and reliable. Thanks iFixIt. Thanks to you, "I FiXED it"!
do I have to remove the mother board to replace the digitizer?
31等其他人完成本指南。
10条评论
Do you have to remove the battery to replace the screen?
Vic Rector - 回复
This worked perfectly for me. I just bought the assembly instead of going through the full deal (which if I had it would have saved me about 30 bucks overall). But was easy enough to do anyway. I still intend to get the digitizer/glass and finish so I have a spare for future breaks. (I have kids and they are hard on these tablets)
After successfully replacing the screen, and reassembling the unit according to the directions, I have a problem with the display image. The unit turns on, but the image does not come on unless I plug un the charger. The image displayed is of the charging batter segmented on 3 different parts of the screen, and lines similar to a schematic. I’ve disassemble the unit, checked the connections, all appear tight, reassembled and the issue is still present.
Any suggestions of what else to look for?
That may be the Samsung battery (actually a single cell) not connected due to the ribbon contacts not mated correctly. Open the phone and check the ribbon connector. Be sure its tip fits flat inside the slot, and the tiny cover fitted on it.
As per the previous comment.
When reassembling the back cover, be extremely careful to fit the cover sideways over the three micro switches (on the right side when seen from the front). These are the power, volume up, and volume down switches. If you fit the back cover incorrectly, the switches may be blocked and not work, or worse be torn off the motherboard. I am writing this because this is what happened to me! I tore off the power switch and I had to salvage the switch from a different tablet to replace it. And that switch is extremely tiny!!
rayramirez - 回复
