跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
你所需要的
视频概述
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
结论
24等其他人完成本指南。
团队
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G3
4 名成员
创作了12篇指南
4条评论
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - 回复
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - 回复
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 45
总计 18,036
