跳转到主内容
Samsung Galaxy Tab 4 7.0 Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Camera Replacement: 步骤 6 中的图像 2,2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - 回复
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: 步骤 7 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: 步骤 7 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: 步骤 7 中的图像 3,3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
结论
9等其他人完成本指南。
Aubrey Goodwin
于08/31/15注册
2,700 声望
创作了3篇指南
团队
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G3
4 名成员
创作了12篇指南
3条评论
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - 回复
पॉप आर्ट मुझे चाहिये
Jagdish Mote - 回复
टॅब पार्ट खरेदी करना है मुझको
Jagdish Mote - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 4,268
