跳转到主内容
Samsung Galaxy Tab 4 7.0 Battery Replacement
你所需要的
视频概述
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
结论
28等其他人完成本指南。
团队
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G3
4 名成员
创作了12篇指南
3条评论
This is for a cell phone, not a tablet. Why?
ckmjunk - 回复
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 49
总计 26,713
