跳转到主内容
Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement
你所需要的
  1. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 2 中的图像 1,1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 4 中的图像 1,1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
    Take note of the red warning comment! Very easy to pull up the connector off the board!!!
    Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
    Ashley Lahm - 回复
  5. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 5 中的图像 1,1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 6 中的图像 1,1
    • Once the battery is loose, lift it out of the device.
    I’m new to working on these devices, but I am wondering why the battery is removed? Is that necessary for this repair? Thanks!
    Tuvy Guss - 回复
    Better disconnect battery before any repairs, therefore reducing the possibility of a short-circuit which could destroy the motherboard.
    Tian Lai Li - 回复
    Isolation tape can also be placed over the connection after disconnecting to prevent any accidental short-circuit mishaps, thus reducing the need to remove the battery.
    Cheers Wayne
    Wayne Lyell - 回复
  7. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: 步骤 7 中的图像 2,2
    • Remove the two 2.7mm Phillips #00 screws from the micro USB port.
    • Remove the micro USB retaining bracket.
  8. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to disconnect the micro USB port.
    • Remove the micro USB port.
结论
12等其他人完成本指南。
Blake Klein
于01/29/17注册
70,531 声望
创作了50篇指南
2条评论
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
Stacie Harper - 回复
There is no need to remove the battery, only detach the power connector, cheers!
Bartosz Kaczynski - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 7,027
