跳转到主内容
Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement
你所需要的
  1. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 2 中的图像 1,1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 5 中的图像 1,1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 6 中的图像 1,1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: 步骤 7 中的图像 2,2
    • Remove the two 2.7mm Phillips #00 screws from the micro USB port.
    • Remove the micro USB retaining bracket.
  8. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to disconnect the micro USB port.
    • Remove the micro USB port.
结论
12等其他人完成本指南。
Blake Klein
于01/29/17注册
71,016 声望
创作了50篇指南
2条评论
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
Stacie Harper - 回复
There is no need to remove the battery, only detach the power connector, cheers!
Bartosz Kaczynski - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 46
总计 7,141
