跳转到主内容
Samsung Galaxy Tab 4 10.1 Home Button Replacement
你所需要的
  1. Samsung Galaxy Tab 4 10.1 Home Button Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Home Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 2 中的图像 1,1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 4 中的图像 1,1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 5 中的图像 1,1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 6 中的图像 1,1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Home Button Replacement, Digitizer: 步骤 7 中的图像 1,1
    • Use the flat end of a spudger to disconnect the home button.
  8. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 8 中的图像 1,1
    • Use an iOpener to weaken the adhesive around the display.
  9. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 9 中的图像 1,1
    • Wedge an opening pick between the digitizer and display frame.
    • Slide the opening pick around the perimeter to separate the two pieces.
  10. Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Home Button Replacement: 步骤 10 中的图像 2,2
    • Lift and remove the digitizer.
  11. Samsung Galaxy Tab 4 10.1 Home Button Replacement, Home Button: 步骤 11 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Home Button Replacement, Home Button: 步骤 11 中的图像 2,2
    • Lay the digitizer face down and remove the home button ribbon cable.
    • Remove the exterior home button.
结论
另外一个人完成了本指南。
Blake Klein
于01/29/17注册
70,510 声望
创作了50篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 22
总计 3,709
