跳转到主内容
修复你的物品
维修的权力
商店
简介
Replacement guide for the front and rear cameras on a Samsung Galaxy Tab 4 10.1 android tablet.
  1. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Peel off the green tape that covers the connectors for the three black strips.
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Use a Phillips #00  screwdriver to remove the four 3.2mm  screws.
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Use the nylon spudger to remove the battery by prying up on the edges.
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Once the battery is loose,  lift it out of the device.
    • Once the battery is loose, lift it out of the device.
  7. Remove the two 2.7mm Phillips #00 screws from the motherboard. Remove the two 2.7mm Phillips #00 screws from the motherboard.
    • Remove the two 2.7mm Phillips #00 screws from the motherboard.
  8. Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard. Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
    • Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
  9. Use a spudger to pry up the motherboard, and remove it from the device. Use a spudger to pry up the motherboard, and remove it from the device.
    • Use a spudger to pry up the motherboard, and remove it from the device.
  10. Pull up on the cameras with a pair of tweezers to remove. Pull up on the cameras with a pair of tweezers to remove.
    • Pull up on the cameras with a pair of tweezers to remove.
结论
另外一个人完成了本指南。
Blake Klein
于2017年01月29日注册
58,009 信誉积分
创作了59篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 15
总计 346
