简介
Before taking apart the tablet, be sure to buy the replacement battery. You can find batteries online by searching, “Samsung Galaxy Tablet 4 10.1 battery.” The battery used in this guide is the 6800 mAh 3.7V.
Below is a link to purchase the recommended battery:
你所需要的
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
Take note of the red warning comment! Very easy to pull up the connector off the board!!!
Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
Once the battery is loose, lift it out of the device.
Better disconnect battery before any repairs, therefore reducing the possibility of a short-circuit which could destroy the motherboard.
Isolation tape can also be placed over the connection after disconnecting to prevent any accidental short-circuit mishaps, thus reducing the need to remove the battery.
Cheers Wayne
52等其他人完成本指南。
5条评论
Well, I know what I did wrong. I thought I was super careful, but I damaged the black connector. (Please pay extra attention to the red warning area in Gunzl’s instructions.) It separates from the board extremely easy. My husband was worried about my taking on this task. I know what I did wrong, but that doesn’t help the fact that I will be purchasing another tablet for him. I’m not sure I will purchase another Samsung, but perhaps all the tablets has such fragile inner workings.
Don’t worry, you’re not the only one! :(
Regarding Step 4, Take note of the red warning comment! Very easy to pull up the connector off the board!!!
