跳转到主内容
Samsung Galaxy Tab 4 10.1 Battery Replacement
你所需要的
  1. Samsung Galaxy Tab 4 10.1 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 4 10.1 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Battery Replacement: 步骤 2 中的图像 1,1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Battery Replacement: 步骤 4 中的图像 1,1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
    Take note of the red warning comment! Very easy to pull up the connector off the board!!!
    Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
    Ashley Lahm - 回复
  5. Samsung Galaxy Tab 4 10.1 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Battery Replacement: 步骤 6 中的图像 1,1
    • Once the battery is loose, lift it out of the device.
    I’m new to working on these devices, but I am wondering why the battery is removed? Is that necessary for this repair? Thanks!
    Tuvy Guss - 回复
    Better disconnect battery before any repairs, therefore reducing the possibility of a short-circuit which could destroy the motherboard.
    Tian Lai Li - 回复
    Isolation tape can also be placed over the connection after disconnecting to prevent any accidental short-circuit mishaps, thus reducing the need to remove the battery.
    Cheers Wayne
    Wayne Lyell - 回复
结论
52等其他人完成本指南。
Samantha Gunzl
于09/30/16注册
629 声望
撰写一个指南
团队
Cal Poly, Team 18-1, Forte Fall 2016 Cal Poly, Team 18-1, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G1
5 名成员
创作了4篇指南
5条评论
Well, I know what I did wrong. I thought I was super careful, but I damaged the black connector. (Please pay extra attention to the red warning area in Gunzl’s instructions.) It separates from the board extremely easy. My husband was worried about my taking on this task. I know what I did wrong, but that doesn’t help the fact that I will be purchasing another tablet for him. I’m not sure I will purchase another Samsung, but perhaps all the tablets has such fragile inner workings.
Racquel Naylor - 回复
Don’t worry, you’re not the only one! :(
Ashley Lahm -
Thank you! Will try this.
affriedl - 回复
the battery on this tablet is terrible, once i get the parts, your guide will come in handy.
kcole - 回复
Regarding Step 4, Take note of the red warning comment! Very easy to pull up the connector off the board!!!
Ashley Lahm - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 51
过去 30 天: 250
总计 52,217
