跳转到主内容
Samsung Galaxy Tab 3 Lite Motherboard Replacement
你所需要的
  1. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 2 中的图像 3,3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
    How to fix back cover only?
    Siva Parthi - 回复
  3. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
    • Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the battery ribbon cable.
    • Use the precision tweezers to remove the ribbon cable from the ZIF connector.
  5. Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 5 中的图像 2,2
    Attention toutefois car le câble ruban est assez fragile et en cas d’utilisation d’une pince de précision on peut assez facilement couper la nappe…
    Grégory MENARD - 回复
  6. Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the seven 4mm Phillips J000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool and gently pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: 步骤 8 中的图像 3,3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard off the case.
    Use the precision tweezers to remove the metal bracket on top of the motherboard by
    pulling up on the tab near the corner. If you don’t the bracket will usually spring off of the motherboard.
    Bill Williams - 回复
结论
21等其他人完成本指南。
Patricia Laird
于02/09/16注册
921 声望
创作了4篇指南
团队
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G1
4 名成员
创作了12篇指南
3条评论
Thank you friend!
nandoquoos2 - 回复
Nice guide, Done very well.
Keith Mullins - 回复
Ótimo guia. Esses tutoriais facilitam demais nossa vida. Sou fã! Parabéns
Amaury Souza - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 7,648
