简介
This replacement guide will walk you through how to replace the motherboard on your Samsung Galaxy Tab 3 Lite. Before doing this, you will need to remove the back case of your tablet first. The guide for how to do that is also included here.
你所需要的
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
This is a long process, so don't try and rush it. Also, be careful about applying pressure.
在这个步骤中使用的工具:Tweezers$4.99
Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
21等其他人完成本指南。
3指南评论
Thank you friend!
nandoquoos2 - 回复 分享
Nice guide, Done very well.
Ótimo guia. Esses tutoriais facilitam demais nossa vida. Sou fã! Parabéns
Amaury Souza - 回复 分享
