跳转到主内容
Samsung Galaxy Tab 3 Kids Battery Replacement
你所需要的
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 Kids  Battery Replacement: 步骤 2 中的图像 2,2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 3 Kids  Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 3 Kids  Battery Replacement: 步骤 4 中的图像 2,2
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
结论
4等其他人完成本指南。
ajhoffman
于01/04/14注册
182 声望
创作了5篇指南
团队
USF Tampa, Team 2-6, Nance Fall 2016 USF Tampa, Team 2-6, Nance Fall 2016 的会员
USFT-NANCE-F16S2G6
4 名成员
创作了10篇指南
2条评论
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - 回复
my screen broke
galixyman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,988
