跳转到主内容
Samsung Galaxy Tab 3 8.0 Rear Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Battery - Open up the tablet: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Battery - Open up the tablet: 步骤 1 中的图像 2,2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Back Cover: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Back Cover: 步骤 2 中的图像 2,2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Battery: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Battery: 步骤 3 中的图像 2,2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Battery: 步骤 4 中的图像 1,1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Speakers: 步骤 5 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Speakers: 步骤 5 中的图像 2,2
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: 步骤 6 中的图像 3,3
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
  7. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect All Relays: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect All Relays: 步骤 7 中的图像 2,2
    • Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
  8. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: 步骤 8 中的图像 3,3
    • Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  9. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove the Motherboard: 步骤 9 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove the Motherboard: 步骤 9 中的图像 2,2
    • Carefully lift the board from the device.
  10. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: 步骤 10 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: 步骤 10 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: 步骤 10 中的图像 3,3
    • Flip the motherboard to reveal the rear camera connection and with tweezers gently lift the connector pins and remove the camera.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 的会员
USFT-BROWN-F14S4G2
3 名成员
创作了26篇指南
一条评论
That worked a treat, thanks a lot Anthony, I don’t quite know when I broke my rear camera but I suspect it’s after being dropped, unfortunatly more than once, a replacement camera was sourced from ebay and only cost £3.29 that included the postage! So all is well again now.
Here’s a link to where I bought mine, I can recommend them 100%
https://www.ebay.co.uk/itm/Genuine-Rear-...
Once again, Cheers!
mooog1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,248
