跳转到主内容
Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement
你所需要的
  1. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Battery - Open up the tablet: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Battery - Open up the tablet: 步骤 1 中的图像 2,2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Back Cover: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Back Cover: 步骤 2 中的图像 2,2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Disconnect Battery: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Disconnect Battery: 步骤 3 中的图像 2,2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Battery: 步骤 4 中的图像 1,1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Disconnect from Motherboard: 步骤 5 中的图像 1,1
    • With a plastic remover tool, gently unseat the connection of the proximity sensor to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Proximity Sensor: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Proximity Sensor: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Proximity Sensor: 步骤 6 中的图像 3,3
    • Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor. The Sensor can then simply lifted from the device.
结论
另外一个人完成了本指南。
Peter Paoletta
于09/22/14注册
2,082 声望
创作了3篇指南
团队
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 的会员
USFT-BROWN-F14S4G2
3 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 2,121
