简介
If your tablet has a broken touch screen glass (digitizer), LCD display or you want to chang the micro USB charging port, loudspeakers, audio jack connector, etc., with this guide we will help you to do it.
你所需要的
视频概述
Put the scotch tape in order not to scatter pieces of glass.
Remove any memory card and SIM card (if the tablet is 3G version).
Remove the two screws and disconnect the charging port flex cable from the main board.
Use a plastic tool to unstick the flex cable from the middle frame.
18等其他人完成本指南。
一条评论
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - 回复
