跳转到主内容
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
你所需要的
视频概述
  1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 步骤 1 中的图像 3,3
    • Put the scotch tape in order not to scatter pieces of glass.
    • Remove any memory card and SIM card (if the tablet is 3G version).
  2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 步骤 2 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 步骤 2 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 步骤 2 中的图像 3,3
    • Using plastic tools remove the back / battery cover.
    • Be careful with the Power and Volume buttons.
  3. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 3 中的图像 1,1
    • Before doing anything, disconnect the battery.
  4. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 步骤 4 中的图像 3,3
    • This step is only if you want to replace the micro USB port flex cable.
    • Remove the two screws and disconnect the charging port flex cable from the main board.
    • Use a plastic tool to unstick the flex cable from the middle frame.
  5. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 步骤 5 中的图像 3,3
    • This step is for only if you want to change the battery.
    • The battery is stuck to the middle panel.
    • Use the white sticker to remove it.
  6. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 步骤 6 中的图像 3,3
    • 2x loudspeackers
    • Power & Volume buttons flex cable
    • Audio jack flex cable
  7. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: 步骤 7 中的图像 2,2
    • Front camera
    • Wi-Fi antenna
  8. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 8 中的图像 3,3
    • Use a heat gun or hair dryer and warm the touch screen glass. This will make the adhesive more flexible and the separation easier.
    • Use a gloves to avoid any injurys from glass.
    • Do not rush.
  9. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 9 中的图像 3,3
    • Beware for the menu buttons flex cable.
  10. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 10 中的图像 2,2
    • Always test the new spare part before final installation.
  11. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 11 中的图像 3,3
    • Transfer the black tape from the old display. It keeps the distance the display from the battery and protects it from overheat.
    • If the adhesive tape is not in good condition you must install a new one.
  12. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 步骤 12 中的图像 2,2
    • Start with reassembling.
    • Did you do it successfully.
结论
18等其他人完成本指南。
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
一条评论
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 25,169
