跳转到主内容
Samsung Galaxy Tab 3 8.0 Audio Jack Replacement
你所需要的
  1. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Battery - Open up the tablet: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Battery - Open up the tablet: 步骤 1 中的图像 2,2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Back Cover: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Back Cover: 步骤 2 中的图像 2,2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Battery: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Battery: 步骤 3 中的图像 2,2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Battery: 步骤 4 中的图像 1,1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Audio Jack: 步骤 5 中的图像 1,1
    • Disconnect Audio Jack from Motherboard.
  6. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: 步骤 6 中的图像 3,3
    • Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 的会员
USFT-BROWN-F14S4G2
3 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 1,789
