你所需要的
With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
Once the battery is removed, it should look as it does in the third picture.
Begin replacement of the motherboard by releasing all connections holding down the motherboard, shown in the first picture.
To do this, use your spudger, tweezers, or a plastic opening tool and gently lift the connections up from their ports.
Once you separate all connections, the back of your device should look as it does in the third picture.
Release the right speaker's connection with either a spudger or tweezers as shown in the first picture. To do this, lift the wire directly up until the glued down wires come off.
Once the connection is released, remove the single screw holding down the speaker, shown in the second picture.
After removing the screw and releasing the connection, you should now be able to remove the right speaker and replace it with a new one.
There is no screw that needs to be removed for the left speaker. All that must be done is to release the connection as done similarly with the right speaker.
Once the connection has been released, use your spudger or a plastic opening tool to lift the speaker up.
After completing this step, you can replace the left speaker with a new one.
6等其他人完成本指南。
