你所需要的
视频概述
With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
在这个步骤中使用的工具:Tweezers$4.99
To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
Once the battery is removed, it should look as it does in the third picture.
Begin replacement of the motherboard by releasing all connections holding down the motherboard, shown in the first picture.
To do this, use your spudger, tweezers, or a plastic opening tool and gently lift the connections up from their ports.
Once you separate all connections, the back of your device should look as it does in the third picture.
To remove the headphone jack, begin by removing the two designated screws shown in the first picture.
Once the screws have been removed, the headphone jack can simply be lifted from the device.
After this step is complete, a replacement headphone jack can be placed into the device where the old headphone jack was, as shown in the third picture.
6等其他人完成本指南。
